Jvc Compulink Control Cable
Discussion in 'Archived Threads 2001-2004' started by DeanB, Dec 18, 2001.
  1. DeanB
    DeanB Auditioning
    Dec 7, 2001
    Can someone please tell me the type of cable the JVC Compulink Cable is?
    Is it simply a stereo cable with mini 3.5mm stereo plugs on each end that I can pick up from any local store or do I need to order it from JVC?
  2. Drew Dockery
    Drew Dockery Stunt Coordinator
    Mar 18, 1999
    108
    I'm pretty sure this is just a standard cable. You should at least try that first as they are pretty cheap, and I can assure you JVC won't be. They charged me $5 for a fuse that should have been about .25 a few weeks ago. Yes, I tried Rat Shack and they don't carry what I needed.
  3. Myram
    Myram Second Unit
    Aug 18, 2001
    292
    I have one of these cables that I am no longer using...it came with my JVC VCR.
    If you are interested send me an email and I'll let you know how much.
  4. JamesDR
    JamesDR Auditioning
    Feb 28, 2001
    5
    The jvc compulik cables are mono 1/8 inch miniplugs. You can get them at radio shack. Hope this helps.
