Brad Bissell
Grip
- Jul 27, 2001
I just purchased the JVC SA70BK progressive dvd player (same innards as sa60/65, 75, 90/95). I seem to have a problem and I'm just wondering if this is normal.
When I switch from progressive to interlaced mode via the remote the image becomes incredibly dark. The progressive image is wonderful and the right brightness, but the interlaced is so dark that you can't see anything but the extreme highlights in movies. I have the unit hooked up via component cables to a Toshiba 40H80.
Also, there is a slight grinding noise when the disk spins up. Do other people have this?? I'm just not sure if this is a usual sound since my old Sony 330 dvd player doesn't make much noise when spinning up.
Any help is appreciated.
Brad
Brad
