JVC 7 disc changer - LAYER CHANGE PROBLEM
Discussion in 'Playback Devices' started by STLMIKE, Jul 21, 2003.
  1. STLMIKE
    STLMIKE Stunt Coordinator
    Sep 2, 1998
    208
    I don't remember the model number, but I've got a JVC 7 disc, progressive scan changer with variable zoom/scaling, etc.
    On some discs (especially older titles), it has a hard time w/the layer change. Sometimes I have to go to a later chapter and rewind to just after the layer change.
    Is this a common problem w/DVD players now (my old Panny A110 never did this)? If it's a glitch, it's annoying but I can live w/it -- however if there's something wrong w/the unit, then I have to try and get it fixed.
    Thanks, Mike
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    I've got what's probably the same JVC from your description. Never had a layer change problem like you describe, at most a 1 second pause but usually almost imperceptible even on older releases.
  3. WesleyHester
    WesleyHester Stunt Coordinator
    Feb 14, 2002
    144
    Selma, AL
    John Hester
    I have the silver 902 and it doesn't have layer change issues.
  4. StephenC
    StephenC Stunt Coordinator
    Sep 2, 2001
    137
    Mike,
    I've had the same JVC for about 6 months and I haven't experienced that problem.
  5. Walt Williams
    Jul 28, 2002
    19
    I've had an XV-F85GD since October 2001 and have never had a problem with layer changes. It's been a very reliable unit and the layer changes happen in a fraction of a second.
  6. STLMIKE
    Sep 2, 1998
    208
    Mine is out of warranty (at least for labor) -- the one time I didnt buy the Best Buy warranty.
    Anyway, the problem is erratic, so I'm just going to live w/it. I ordered a clearanced Panny RP91 to use for movies, and keep the JVC to load a whole season of Star Trek at once :)
    Mike
