just upgraded to a 6.1 (1 Viewer)
junebug
Leclerc Nesifort
does it make a real big differents if you are using a center channel speaker for the back surround channel then a regular surround speaker
Paul_Dunlop
Hi
I am using a rear center channel for my 6.1 setup
It is identical to my front center channel
For my smallish room (8'x16'), I think it's perfect
Ed Moxley
Eastern NC
Ed
A regular surround speaker will do just fine, though either will work well.
If you're using a stand, or hanging on the wall, the surround speaker will work better, I think. But if it's sitting on a table or shelf, a center channel will work good.
I don't know that one has an advantage over the other, unless your surround speaker is larger than the center channel. Then it will have bigger woofer(s) in it, and may sound a little better, in the long run.
Good luck!
junebug
Leclerc Nesifort
thanxs a lot guy Im really an greatful for your replies
Staff online
Digital Dan
