Hey all, I just installed XP pro on my old computer to upgrade it from Win 98 and reformat it. Everything seemed to work fine except that if I go into the programs folder on the c:/ it still has certain program folders in it from my old OS which don't show up under the add/remove programs list, the main one I noticed is DVD profiler.When I did the install I did not do the upgrade option, rather I did the new install option to reformat the drive.
Any ideas as to why this happened? as far as I can tell the computer now has no programs on it other than the bundled ones with XP, so why would the program folders stay for certain programs if the computer has none on it? thanks.
