Just ordered my 20-39CS and Samson 700!
Discussion in 'Archived Threads 2001-2004' started by Craig_B, Mar 6, 2002.
  1. Craig_B
    Craig_B Agent
    Mar 5, 2002
    25
    After all of the agonizing deliberation, I finally ordered my my 20-39CS and Samson S700 from SVS. Now that I have made up my mind, please don't reply to my eariler e-mail and tell me I should get a CS+, I have already started second guessing myself and I really don't need any help! [​IMG]
  2. Juan_R
    Juan_R Supporting Actor
    Sep 4, 2001
    683
    I have the same setup and I cant imaging going any higher in ouput. Dont worry you got a killer sub there, you will see and hear.
  3. Loring
    Loring Stunt Coordinator
    Sep 11, 2000
    71
    Just remember to calibrate your system. And make sure everything is set up correctly.
    * Speakers set to small on your receiver.
    * Subwoofer set to on.
    * Make sure your SA is out of the house to do calibrations and testing.
    Then calibrate with V.E. or Avia and start listening to the bass. Then after everything is setup start throwing some bass heavy DVDs at it. My first choice would be Star Wars: Episode I.
    By the way, I will be getting the same SVS setup here in a bit just waiting for my tax return to come in.
