Just ordered an RP-82. Advice anyone?
Discussion in 'Archived Threads 2001-2004' started by RANDY FISHER, Nov 14, 2002.
  1. RANDY FISHER
    RANDY FISHER Second Unit
    Sep 1, 1998
    285
    Ok, I just ordered an RP-82 from Onecall.com for $206.10 delivered. What should I look out for when setting it up next week. I currently have a Sony 700p hooked up via component to my 36" Sony XBR400. Does progressive but I am dying to try out a player with no chroma bug and the Faroudja chip, and the price was right.
    thanks Randy[​IMG]
  2. DougR
    DougR Second Unit
    Jun 15, 1999
    354
    Me Too....me too !!!!
    I just order one from them this morning .[​IMG]
    [​IMG]
  3. MikeSRC
    MikeSRC Second Unit
    Jul 19, 2002
    369
    Set "transfer mode" to Auto 1 and "picture" mode to Normal to start. After you've viewed a few DVDs, you might want to try the Cinema 1 or 2 picture modes, but always leave the transfer mode on Auto 1 to use the Faroudja deinterlacing. Make sure the progressive light is on (on the front panel if your using that output (seems simple, but I've seen a lot of people think it's been turned on when in fact it hasn't).
  4. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    You also have to enable progressive mode in the player setup menu in order for the button on the front of the player or the progressive mode menu item in the "display" menu to work. It ships with progressive mode disabled.
  5. Allan Mack
    Allan Mack Supporting Actor
    May 26, 2001
    614
    If you haven't already done so, fix the red push on your XBR400. The RP82 seems to push a little red itself:
    http://homepage.mac.com/mscott/xbr400.html
    Otherwise, it's pretty much set and play. Just leave it in Auto 1 and Normal picture mode...
  6. MikeSRC
    MikeSRC Second Unit
    Jul 19, 2002
    369
    Can't say that I've experienced this. My RPTV was calibrated to 0% on red, blue and green with another DVD player (JVC), and the RP-82 is right on with those settings. I have had to kick up the black level (brightness) a bit though.
  7. Allan Mack
    May 26, 2001
    614
    The RP82 definitely pushes the red more than my previous player, the Panny DVD-RV31. I have the 36" XBR450...
  8. RANDY FISHER
    Sep 1, 1998
    285
    Thanks for all the posts so far guys!
    Randy [​IMG]
  9. AndyN
    AndyN Agent
    Jan 20, 2001
    25
    Sorry to ask this in your thread, but what is everyone using for their video settings, specially the block and mosquito noise stuff. Also where is the rp82 "accurate" on its brightness and contrast settings?
    Andy
  10. RANDY FISHER
    Sep 1, 1998
    285
    I haven't touched the block noise settings. Does not seem to need it. Also, I use the "lighter" black level setting and I have settled on the "Cinema 1" instead of "normal" picture setting. I did not adjust the internal picture sttings of the player otherwise. Anyone else care to comment.
    Randy
  11. mike_snazzy
    mike_snazzy Extra
    Nov 23, 2002
    19
    just ordered 2 yesterday from onecall.com. Will be here tuesday.
