RussellC
- May 2, 2000
I just got my 45tx and rewired my system and I'm all set up now. I have Energy Take 5.2 speakers and a SVS sub just for reference. I set it all up, ran the MCACC (which is really cool, by the way) and then change my subwoofer distance a little and change the x-over from 80 to 100Hz.
It sounds great so far, my sub has really come to life. My question is this. It seems to only let you choose between certain modes like THX CINEMA, DPL2, Neo6 etc... How can I set it up so none of these are active? I just wants straight DTS, DTS-ES or DD, DD-EX for DVD's. My understanding from the manual is that I should put it on THX CINEMA and it will set everything correctly. Or is there some other mode to do this? Thanks for the help. Now I have to order my Surround Back speakers.
-Russell
-Russell
