Just got a BDP-550 and have a few questions (1 Viewer)
David Lindon
I have the 550 connected to my TV via HDMI and analogue outputs to my Receiver
The first question is the picture looks very grainy so to speak. Is there anyting I can do or is that how its supposed to be?
Secondly there seems to be very little coming from the rear speakers. when I press 'display' on the 550 remote, it says DTS-Master audio 2.1. I'm assuimg thats because I've got it hooked up with a HDMI to the tv but should it say 5/6 .1 ?
Rodney
David:
I am not using HDMI, but the picture shouldn't look grainy, depending on the source. What disc are you playing?
Secondly, what are the audio settings you selected for the player?
David Lindon
I've tried Street kings, Dark night and terminator 2 and all are very grainy.
As for the sound options, I have:
Audio output priority: multi channel analogue
Speaker sizes and distances etc: all ok
Audio HDMI: auto
BD Audio: Direct
Autio ATT: Off
Dolby Digital: Dolby digital
DTS: DTS
AUDIO DRC: auto
Downmix: Normal
any ideas?
Rodney
The audio settings seem fine. Depending on the source, you should be seeing either DTS-Master audio 3/2.1 or DTS-Master audio 3/4.1. Try hitting the display button and then changing the audio, and see what choices come up.
TheThrillisgone
