Dennis Ellis
- Jan 2, 2001
Not sure where to start. I purchased a sony 12" sa-wm40 sub along with the jbl nsp1 speaker package. All of this is hooked up to my onkyo 575x receiver.
I hooked it up last night (except for the rears) and I am not impressed. I have read numerous reveiws on the nsp1's and the overall concensus is that they are really good.
1. Where do I set the knobs on the sub? I'm at work now so I can 't recall what the labels are.
2. Why is is that when I had my cheaper KLH bookshelfs hooked up I only needed to put the volume on 35 for normal tv shows, etc? Now with the n24's I have to turn it up to almost 50 before I can get the same volume of sound.
3. This is in a relatively large size room. I don't seem to get alot of midrange/bass sound. just highs and lows. I do have my n24's set to small. WOuld it hurt if I set them to large? Would that allow more midrange/bass to come through? Or does it fall back to the sub not being configured properly?
4. Any other tips on how to improve the sound of this setup? I feel like I may have just wasted alot of money. Don't get me wrong, the n24's are alot more "detailed" than the klh's but I honestly think the klh's had a better range of volume.
Thanks for any help.
Dennis
Dennis
