Zane Johnson
- Jun 15, 2001
ok i have an 8X DVD ROM, an ATI Radeon 32mb DDR video card, a 21" moniter, and a JVC RX8000VBK reciever. up intil last week i used to watch all of my DVD's and any other video sources through my moniter because i had a TV tuner card in my PC, but now with my new vid card that's not possible anymore. So my question is, how can i hook all of this back up? i mean i know what i need to do just have a few questions.
First off, with the DVD rom and the ATI Radeon, the DVD picture quality is much better than it was with my playstation 2 and the moniter, only problem is i can't output the digital bitstream to my reciever because i have an analog sound card in my pc. ok, here's the dilemma, the DVD rom has two outputs on the back of it (analog audio) which is a four pin connector THAT IS CURRENTLY IN USE and works great, for analog audio out of my 2 stereo speaker and subwoofer speaker system on my computer. And there's a (digital audio) output that is not in use right now, it is a 2 pin connector. So, how do i get the digital signal to the reciever? do i need to buy a digital sound card such as the Sound Blaster LIVE or Audigy to pass the signal through it's coaxial output to my reciever? and if this is the case will i need to buy some sort of a 2 pin cable to go from the "digital audio" output on the DVD rom to an input on the sound card the way the "analog audio" cable is now??? OR, can i buy some sort of cable to go directly from the 2 pin "digital audio" output on my DVD ROM to the coaxial input of my reciever????
i'm hoping the second way is possible, anyways thanks in advance
Zane
Zane
