Jurassic Park DVD, does your system do this? (1 Viewer)
Dan Kolacz
Hi,
Just trying to determine if there is a problem with my display or DVD player.
I have the Dolby Digital version of Jurassic Park.
In chapter 14, 38-42 seconds into the chapter. Look at the left hand side of the screen at the background mountains. Do you see a noticeable flicker? If you use the slow motion controls you can see it as well for those few seconds.
I have notice subtle brightness flicker throughout this DVD and many others. Is this normal?
Joe McKeown
Just a WAG on my part, put it almost sounds like macrovision. Is the player's video hooked DIRECTLY into the TV, or does it go through a receiver, VCR, or other video switcher before hitting the TV?
Dan Hitchman
It's because you have the DD version! :D
Seriously though, you ought to consider trading up to the corrected DTS version. Much better sound. Almost to the DTS LD level.
Dan
Brenton
It's because you have the DD version! Seriously though, you ought to consider trading up to the corrected DTS version. Much better sound. Almost to the DTS LD level.
Ah, but the DTS version is severely lacking in extras. As for me, I don't have a surround sound system yet, so it was the extras that were the deciding factor for me.
Dan Hitchman
Brenton,
I'd keep the DD version for the extras and get the DTS version for the movie and the sound so you're set when you have a DTS processor.
Dan
OttoIsHere
