JL Car Sub for HT
Discussion in 'Speakers' started by JunoVazquez, Jan 6, 2004.
  1. JunoVazquez
    JunoVazquez Stunt Coordinator
    Nov 11, 2003
    79
    I have the twin JL 12" Powerwedge that I will be extracting from my SUV. It's being powered by a HC sub amp. My plan is to integrate it with my HT setup. I have a DC power adaptor to power the amp.
    Has anyone tried using this kind of setup?
  2. TanT
    TanT Stunt Coordinator
    Dec 17, 2002
    135
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    I would be surprised if it worked well at all.
    Car audio subs tend to be short throw. Long throw is really what you want for HT...
  4. Shawn Solar
    Shawn Solar Supporting Actor
    May 12, 2001
    763
    High power amps are a dime a dozen these days. It is very easy to pick up a 500-1000watt amp for under $500 even $300. If you don't want to buy a mega watt amp and use what you have then you could do so, but a home/pro amp to me looks a lot nicer, probably will work better too. Its ultimately up to you and I have heard of people use a similar setup. I would also suggest getting the T/S parametres and designing a box more sutible to HT enviroment.
  5. TanT
    Dec 17, 2002
    135
    Some of the newer auto sub drivers have very high Xmas
    For example: the Adire Brahma has 28mm one way linear according to Adire.
