Jensen JS800 sub replacement (1 Viewer)
Picture_Shooter
Mike
Finally the little terd blew (Jensen JS800). It has been popping and now the VC finally died.
Looking for a nice replacement of this original 8" sub for this cabinet. Willing to spend up to $100.00 sub.
The amp is 100watt and has plenty of UMPH for room it is in.
So any suggestions of which sub to put in this cabinet, please post.
Thanks you for all of your help.
J
Robert_J
Mississippi
You want to replace the driver only? Then we need a few things from you. How large is the opening. Measure as accurately as possible. 1/16" of an inch would be great. Same when you measure the internal volume of the cabinet. If it is ported, we need to know the diameter of the port(s) as well as their length. Only then can we start to look for replacement drivers.
Remember that the amp may have EQ built into it so the new driver may not play up to its potential. But I will recommend the best one I can find based on your budget and the information above.
-Robert
eathree
