JBL vs Polk
Discussion in 'Speakers & Subwoofers' started by brandon_len, Feb 4, 2004.
  1. brandon_len
    brandon_len Auditioning
    Jan 28, 2004
    5
    I was hoping someone could provide their opinion on a speaker decision. I currently have the JBL scs136 speaker system. I want to upgrade the center channel. I am on a budget and am trying to decide between two speakers. I have found an open box Polk CSi30 for $115 at CC. I am alos considering the JBL N-center for around the same price with shipping. What is your opinion on which to buy and how much of a difference do you think haveing a polk center with JBLs would there be in sound. Thanks for any opinion you have.
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Those two are very different timber....
    What is it you do not like about the current center? This could reveal the best choice for you out of the two.
  3. brandon_len
    Jan 28, 2004
    5
    It sounds flat to me. It just doesn't have the fullness that these two speakes have. Voices don't sound natural. It is hard to describe. The problem is I haven't been able to compare them side by side as I have not found a store that carries both brands ie JBL and Polk.
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    The Polk is a little shrilly to me (not enough bass), the JBL is a little dull but fairly full sounding with decent bass responce.
  5. Luitz
    Luitz Stunt Coordinator
    Jan 4, 2004
    139
    Prolly cuase its using a 3.5 inch driver.
    Find a Jbl (Just be Loud) center with 5 inch or larger in it. Timbre should be dam close
  6. Luitz
    Jan 4, 2004
    139
    Find a Jbl (Just be Loud) center with a 5 inch driver/s or larger in it. Timbre should be dam close
