JBL Studio series in white? (1 Viewer)
Brian Warren
are the only Studio series in white the S36's AW? I would not want to wall mount black speakers.
thanks
brian
Jason Wilcox
Those white s36's are all weather speakers. So you're going to be paying more for them just because they are white (your not using them outside right?). JBL (non-all-weather) studios also come in cherry and beech.
Brian Warren
not only are they all weather but I bet they dont sound as good with the plastic housing. also, in the studio or northride, thet have no dipoles and I believe most all HT audiopliles rec. dipoles for the sides.
James Zubb
All S36 have plastic housing, not just the AW. FWIW I think they sound fine as surrounds.
Phil Iturralde
One reason why I bought four JBL S26s (& timbre-matched S-Center), to anchor the Front & Surround corners, so I could reproduced the Encoded DD 5.1 and hear the surround effects the way the Recording Sound / Mixing Engineering intended them to sound.
Once you've experienced your 5.1 Blockbuster DD/DTS DVD's surround effects with, at the very least Four Identical Speakers anchoring your corners (w/timbre-matched Center) in your HT/family room, ...you'll never go back!!
Phil
Chris Tsutsui
"did you know that more than 70 percent of the world's great recording studios monitor on JBL loudspeakers?"
I also found out that more than 80% of THX certified commercial theaters use JBL equiptment."
If I wanted my 6.1 soundstage to be delivered over a wide range of audience then YES I'd use dipoles. But because my HT is dedicated to 1 or 2 person use I prefer the sound of "monopoles". Having multidirectional speakers tends to cause unwanted reflections and will begin sounding more like Bose.
The JBLs in Beech is pretty close to white. I'd get Beech if I had to choose a series II (silver cone) JBL speaker because beech looks like maple. Maple is one of my favorite modern woods, one that I'd almost consider to be an exotic. :)
CoolMovies
