JBL Speaker setup
Discussion in 'Speakers & Subwoofers' started by Kevin Ven, Mar 31, 2005.
  1. Kevin Ven
    Kevin Ven Auditioning
    Mar 29, 2005
    3
    HI all this is my first post in this forum, I’ve been reading this forum for some time now and you all have some good advice so here is my question, I would like to know your thoughts on the following speaker setup, first of all the room size is 12’X28’X8’ with one window 7’X5’, the speakers I’m looking at are JBL Northridge series.
    E30 for front L and R
    EC35 Center
    E20 rears
    Sub? for lack of funds
    This is a low budget setup my receiver is a Pioneer dsx 415 and the TV is a Toshiba 32” Cinema series flat screen.
    I would like any input you might have Thank You.
  2. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    You def. need a sub, go check out the Dayton 10" at partsexpress for $124. I would also use E30's for surrounds if using them up front as well, otherwise, loooks fine.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    With e30's for mains.. You really are going to need a sub.
    Go with e50's for your mains / fronts at least if you really can't run a subwoofer....
    An inexpensive sub with e30's may be cheaper than e50's with no sub and probably perform better though.
  4. EricCrane
    EricCrane Agent
    Aug 6, 2004
    45
    If you don't listen to 5 channel music I would just get some inexpensive speakers almost anything will do for rears and put more money into a sub or better fronts. With the money you save by not buying the e10s you could upgrade your fronts to e60s.
  5. Kevin Ven
    Mar 29, 2005
    3
    Thanks for the replies, I do plan to buy a sub but I am doing this piece by piece starting with the ec35 center.
