JBL S38 II size
Discussion in 'Archived Threads 2001-2004' started by Brad A, Dec 20, 2002.
  1. Brad A
    Brad A Agent
    Nov 15, 2001
    45
    I just got a pair of JBL S38's as my mains...I have an Onkyo TX-SR600 receiver..Under "Speaker Configuration" should I set the speaker size to Small or Large ??? (Seems to me there should be a medium option)
  2. Tony Genovese
    Tony Genovese Supporting Actor
    Oct 5, 2000
    811
    Small if you have a sub, large if you don't.
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    What Tony said. The choice of words here is very poor. I'd still set great big towers to small if I had a good sub. Small just means the crossover is used and the lowpass is sent to the sub. Large means the crossover isn't used and nothing goes to the sub (except the LFE channel).
  4. Joe Sabato
    Joe Sabato Auditioning
    Nov 11, 2002
    13
    Set them to small, I have S38's and have tried them both ways (using 2 subs), the extra "headroom" you get by not pushing the woofer in the S38 translates to cleaner sound at high volumes.
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    The size setting has less to do with the physical size of the speaker, but rather the frequencies it is capable of. This setting simply determines where bass below a certain point is sent. To add to what Tony said, without a sub, setting the speakers to small will do you no good, and in most cases is not even possible.
  6. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,850
    728
    9,110
    Since 2006
    Cameron Yee
    I had mine on "Large" for a long time, until I acquired an SVS sub. Getting an SVS sub also educated me on what constitutes "boomy" bass. So I agree with the post that says to set to "Small" if you have a good sub.
  7. Brad A
    Brad A Agent
    Nov 15, 2001
    45
    Thanks for all the replys...I guess I have a decent sub...Sony SA-WM40
  8. Cameron Yee
    May 9, 2002
    11,850
    728
    9,110
    Since 2006
    Cameron Yee
    The Sony is the sub I had before the SVS. Ultimately it comes down to your preference and I still have varying preferences for sub placement. It seems no matter where I have the sub I can localize it, so up front with the mains is usually best. I read somewhere that if other sources are putting out bass then bass in general is harder to localize. Hence I had my speakers set to large. It also seemed to be the best compromise between music and DVDs.
