Well within the next few weeks I am looking to round out my JBL system with some S36 speakers for the surround channels. My question pertains to the mounting of the channels on my apartment walls. I want to side mount the speakers and my only options for doing so are to put the units at least 7 feet high up on the wall. Will this work well with these speakers? Mounting them on the rear wall isn't ideal because my couch sits right there on the wall and I think the speakers would be too close for comfort. Any advice would be appreciated . Brandon Smith
I've shot you an email showing how mine are mounted behind my couch. You should not have any problem mounting them on the side wall... 7ft is a bit high, you might try six and see what that will do for you. Mine are six and look really high.
