JBL S310II's vs S312II's
Discussion in 'Archived Threads 2001-2004' started by Keith AD, Aug 5, 2002.
  1. Keith AD
    Keith AD Auditioning
    Jul 30, 2002
    4
    I currently have the JBL SCenterII, the S36II for the rears and an SV 39-20 subwoofer. My last piece of the puzzle is the fronts. The debate is between the S310II's and the S312II's. The only difference seems to be the 310II has a 10" bass driver while the S312II has a 12". The price difference is about $100 for the pair. With the SV sub do I really need the speaker with the bigger bass driver or will the S310 suffice?
  2. Stephen Houdek
    Stephen Houdek Second Unit
    Jan 21, 2002
    326
    S
    FWIW Keith,
    I auditioned both and liked the fuller sound of the S312 better than the S310. If you run them as small I would bet you'd notice little difference. I don't have a Sub yet and wanted 12" cones for bass until I decide which subwoofer I want.
  3. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    The S310 will suffice IMO. Since you'll likely be running them small there probably won't be a difference.
    I actually prefered the sound of the S38 bookshelf over the floor standers. The floor standing speakers give off fuller sound, but it didn't appeal to my taste.
