TommyL
- May 27, 2002
Hi all...There is so much talk about the JBL and axiom lines...which one would be the overall best...not money wise, but performance wise...would the money difference be worth it to goto the axioms, or would you put the money you save into a better receiver? Axioms with vp150 center, 4- m22's and 4 stands will run 1200 bucks US...4- JBL s26's, and JBL s-center 500 bucks + stands...Leaving me with 700 for a new receiver(I use a 5240 yammy)...thinking about a marantz 6200....which would you bite on? any thoughts would be great! My room is 12x14x7' ...about 5-6 feet from the fronts...I use it mainly for movies and xbox thanks much! TL
