JBL NSP1 Speaker Wire
Discussion in 'Speakers' started by Justin Friedman, Oct 14, 2003.
  1. Justin Friedman
    May 29, 2003
    37
    Hi,
    I'm planning on purchasing the JBL NSP1 speaker set and was wondering if it comes with speaker wire. If it does, is it good quality or should I buy other cables? I will be pairing it with a Pioneer 45TX. How are Ixos or Accoustic Research for speaker wire? Thanks!
  2. Phil Iturralde
    Phil Iturralde Screenwriter
    Oct 7, 1998
    1,867
  3. Justin Friedman
    May 29, 2003
    37
    The NSP1's accept banana plugs, correct? What brands of speaker wire can I get with banana plugs already on the ends that are good from, say, best buy? Thanks!
    P.S. Doy you have something that alerts you whenever NSP1 is in a post? : )
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    No offense, and not that these speakers are bad, but a 45Tx with NSP-1s? As mains? Sounds like a mismatch and a half to me. If you haven't heard the NSP1s, I'd have to say this the allocation of funds is very dispropotionate, as the speakers are going to make the biggest difference in the sound of the system. What sub will you be using?
    I have never seen pre-terminated wire at Best Buy.
    Yes, Phil has JBL radar. [​IMG]
  5. Justin Friedman
    May 29, 2003
    37
    right, I'm just getting the NSP1s for now due to space constraints and the fact that they're only $200. Rest assured I will be getting bigger speakers eventually when I have something that remotely resembles a living room : )
