Pus Suchre
- Feb 27, 2004
I bought a pair of N24IIs off of e-bay for $68- in truth I wasn't expecting to win them. I decided to use them as my rear surrounds- they are easy to mount and don't take up much room- which are both pluses.
I still need to get my regular side surrounds (for 5.1)- and I was leaning towards the better E20s. The E20s will be more difficult to mount on the wall- and will take up more space in a somewhat tight room- 9'10" wide.
The real issue is space. If I had my choice I would use the E50s for all 4 surrounds- but no way would they fit.
So the question is:
Am I better off matching the side with the rear surrounds and buy another pair of N24IIs?
+ easy to mount
+ sounds decent
+ takes up little space
+ pretty freaking cheap
+ would be an exact match with what I already have
Or should I go with the E20s
- more difficult to mount
- takes up more space
- not as cheap
- doesn't match my rear surrounds
++ should sound better
Hmmmm, the real question may be does the E20 sound that much better than the N24IIs? I have nowhere to demo the difference- so your thoughts are appreciated.
If it matters, my fronts are E100s, with an EC35 center and an SV20-39PCi sub.
Thanks for any thoughts!!
-Pus
So the question is:
+ easy to mount
+ sounds decent
- not as cheap
-Pus
