JBL N24II wall mounting brackets
Discussion in 'Speakers' started by Walt H, Jul 19, 2004.
  1. Walt H
    Walt H Stunt Coordinator
    Aug 5, 2000
    209
    Do the old JBL N24II speakers come with the built-in keyhole mounting brackets alredy on the back of the speakers?
  2. Greg-ST
    Greg-ST Stunt Coordinator
    Jan 27, 2003
    193
    Only the threaded hole is on the back of the speaker. The included mounting kit will have to be attached.
  3. Walt H
    Aug 5, 2000
    209
    Is the "mounting kit" the keyhole type? I have curved molding around the top portion of the room and I have curved picture handgers which fit perfectly onto the molding. All I need is something I can run heavy weight fishing line through, then hook the line, with speaker, over the bottem curve of the picture holder.
  4. Greg-ST
    Jan 27, 2003
    193
    Keyhole type? Nope. It has a ball joint mount.
    Here's some images courtesy of Phil's HT Website
    [​IMG]
    [​IMG]
  5. Walt H
    Aug 5, 2000
    209
    Thanks a lot Greg-ST.
