Kenneth Harden
- May 13, 2002
I was bored and took my sub apart.
Part of the reason was I wanted to check and see if the mounting screws (JBL, thanks for using hex heads - philips should be BANNED for anything other than construction or stuff that NEVER needs to be taken apart) were loose. Sure enought, they were almost FINGER TIGHT into the cabinet - so before torquing them down, I took them out. Here is what I found (NOTE: I will edit comments in later, here are seven pictures):
Oh stars, the host is not letting me hotlink, here: (check out the last seven pics)
http://www.pbase.com/canonken/home_theater
