Mitch N
- May 11, 2004
I recently purchased the Jasper Jig Model 200 unit to hopefully make cutting circles easier and quicker.
I must say that it does work as advertised, however
there were some issues that caused me to throw it away
after just a few uses.
I could have emailed this post, but their website is outdated and the email address is no longer valid. So I might as well post it all in case your tempted to get one of these things.
1. The silk-screening for the Model 200 should be on
the topside of the jig, rather then face down while
attached to the router. Although not difficult to
match up the pinhole with the correct diameter
marking, it was an inconvenience to half to look a
little harder using sunlight to find the exact
hole.
2. The choice of material for the Jasper Jigs is not
adequate. It should be made of Lexan, or aluminum
(preferred) this is why I threw mine away. It was not
rugged enough and cracked at the mounting holes when I
was moving my router with the jig attached off of my
worktable to another location. Acrylic is a rather
strong and flexible material, but can also be rather
fragile and crack. Lexan would be a better
alternative. But ultimately if it were some type of
aluminum, it would be rugged enough and last forever.
3. The manual although fine for it's purpose, I felt
that it could be improved upon. More pictorial's, and
more tips rather then just text.
If I'm going to buy another jig, I may get one of these.
http://www.glassmanscustomforum.com/tools.html A lot more expensive, but should be much more rugged.
Oh and you can never have enough clamps! I have a couple C clamps and 4 24" bar type clamps and I could have used another set of 4 bar type clamps.
hole.
