Jasper Circle Jig
Discussion in 'Archived Threads 2001-2004' started by Blake Middleton, Feb 27, 2002.
  1. Blake Middleton
    Feb 28, 2001
    46
    It looks like Jasper audio raised the prices on all their jigs. Now the 300 model is 45.99! Didn't it use to be around 35? Does anyone sell this for any cheaper? I can't see spending over $50 for a piece of plastic with holes in it. Thanks.
  2. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    Another solution is to get some hardboard (masonite) and build your own. Attach the router to one end and drill the hole for the pin at the correct position. You will want to cut an opening on the router end (for sawdust to escape).
    Greg
