Lee_eel
- Aug 4, 2002
Just read over at DVD File that Jason X will be a digital to digital transfer. That's got to be good news!
As for the print...Yes I've seen it many, many times.
I had to check every reel as it was scanned.
I don't know what anyone knows about how we made this film,
but it was the first 100% digital film...
We shot it on film but then transfered every frame to HD...digital.
We did all the post in the digital world...
effects, editing, color, you name it.
We created a 24 frame conform in HD...We never cut or touched the neg.
Then, when I was happy with the cut and look, we scanned every frame
back to film. At the time nobody had done that before.
Well it worked and the print looks great!
http://www.fridaythe13thforum.com/s...Jason+x+digital
Live-action scenes were photographed in 35mm three-perf format, which is a technique Underschultz has used for television programs. Along with accommodating the visual effects team, there was inherent savings in film and lab costs. Many sets were extended and the CG images composited during the digital post-production process.
"The size of a 1.85:1 full aperture image on a piece of negative film fits entirely within three perf," says Underschultz. "Since we were never cutting on film, there was never the requirement to have a four-perf negative to cut with. It was a budgetary decision that we would use the money saved shooting to create stronger visual effects."
Jim Isaac, director of Jason X.
The entire original negative was converted to high definition format with a Phillips Spirit DataCineTM at Toybox in Toronto. Many shots were augmented with CG elements and other visual effects. The digital master was color-timed in HD format at Toybox and it was transferred to four-perf Eastman color intermediate film with an ARRI laser recorder.
"Even though postproduction and mastering was done in HD format, it was clear that we needed to originate on film to get that dreamlike look that audiences associate with fantasy," says Underschultz. "HD video images can't compete with the look, feel and latitude of film."
Underschultz used a Panaflex Millennium camera and Primo lenses. The three-perf negative was exposed side-to-side and top-to-bottom, providing additional space for extending sets in digital post. The effects shots were carefully worked out in pre-production to accommodate special effects.
http://www.kodak.com/country/US/en/...01/jasonX.shtmlShould clear up confusion.
We shot it on filmSo the director shot the movie with film cameras, then transferred it to digital. Is that correct? If so, that's not the same as using digital cameras.
So the director shot the movie with film cameras, then transferred it to digital. Is that correct? If so, that's not the same as using digital cameras.Uh... yes.According to the director and DoP.
Are there any other digitally shot movies other than these 3?Thousands of low-budget movies have been shot on consumer grade DV,which is basically what Soderbergh shot Full Frontal on.
What Spy kids 2 and Episode 2 were shot on is much higher quality than condumer grade,obviously.
