Jamo E805 4-8 Ohms Question
Discussion in 'Speakers' started by Niti, Jun 6, 2005.
  1. Niti
    Niti Extra
    May 7, 2005
    21
    The Jamo E805s are rated 4-8 ohms and states it on the back of them. Does this mean that the receiver will drive the speakers at 4, 6, or 8 ohms? What ohms will the receiver drive the speaker at? Hoping either 6 or 8 since 4 is pushing the receiver...LMK. Thanks!!![​IMG]
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Impedance is frequency dependant, so there isn't a simple answer to the qestion. 4-8 means, they are likely 4 Ohm nominal, something along the lines of Paradigm Studios, which say 8 Ohm "compatible", because they do drop fairly low (2.8 Ohms or something similar). I checked around, and most websites list those speakers as 4 Ohm. They also seem to have a low sensitivity of 86dB. You're going to want plenty of power to drive them most likely, depending on your room.
