Jagged edges help?
Discussion in 'Displays' started by Tony_K_E, May 28, 2005.
  1. Tony_K_E
    Tony_K_E Auditioning
    May 27, 2005
    I just installed a Sharp XV-Z12000 projector. While I'm waiting for my long component cables to arrive, I connected with a standard video cable. I can see periodic jagged edges on some images on screen. WIll those disappear once I connect with component cables?
  2. JohnnyKretentiv
    JohnnyKretentiv Stunt Coordinator
    Nov 8, 2004
    65
    I would be very confindent that they will be SIGNIFIGANTYLY reduced if not eliminated. Go get some component or DVI cables ASAP! They really to make a diffence.
    What sources are you using?
