I've got $2k for 5 bookshelf speakers. Whats your thoughts?
Discussion in 'Speakers & Subwoofers' started by Greg Risley, Jan 13, 2004.
  1. Greg Risley
    Greg Risley Second Unit
    Sep 21, 1998
    288
    Alright, the new Sony STRDA5000ES receiver is on the way and it's time to upgrade the speaks. I have a dedicated room that is 18' x 12' with an 8' ceiling. I want to go with 5 or 6 identical monitor style speakers, tired of dealing with floorstanders and I have 2 Velodyne subs for the bottom end.
    Let me know what you like.
    Greg
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    For Sony?? I'd go with Klipsch or something rather forward and bright.
    To say Sony AVR's are laid back is a way understatement.
  3. CalvinCarr
    CalvinCarr Supporting Actor
    Dec 4, 2003
    512
    What do you mean by way laid back on the Sony? Everything I own is Sony and plan to upgrade my AVR with a higher end Sony but am scared because of all I have heard on here about them. I was doing it more for comaptibility and looks more than anything plus I have the 18 in 1 sony remote.Shed some light for me. I plan to spen about 1k.
  4. CurtisSC
    CurtisSC Screenwriter
    Jan 28, 2003
    1,412
  5. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    Swan's Divas from www.theaudioinsider.com are also a great choice. You could get 6 2.1s in rosewood for about $1500 or 6 in Black Cherry for around $1200.
    W/ the price difference (and possibly some revenue from selling your velo's) you could pick up one or two SVSs. If you're completely satisfied with your Velos then you could just come in way under budget and be really happy [​IMG]
  6. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    Curtis has a fine suggestion, to which I would add the Rocket 250s, six of which would be enough for AV123 to give a package discount from the listed $2,100 price.
    They are rear ported, so you do need a bit of room behind the speakers.
  7. dan-0
    dan-0 Stunt Coordinator
    Aug 1, 2003
    156
    Are you going to need a matched center?
    Anyway, 5 NHT SB-2's would run, max., $2,000.
    Worth a thought.
    NHT SB-2
  8. Charles Gurganus
    Charles Gurganus Supporting Actor
    Mar 2, 1999
    689
    You can get SB-2's for $400 a pair.
  9. Richard_B
    Richard_B Stunt Coordinator
    Oct 14, 2003
    137
    To go along with all the great recommedations given so far another popular choice would be the Paradigm Studio 20s.
  10. cabreau
    cabreau Second Unit
    Dec 1, 2003
    322
    I was just going to say Paradigm Studio 20's. I have some and they sound spectacular. For the center, I suggest a CC-470 to match. You should be able to get everything for JUST under $2000.
  11. Greg Risley
    Sep 21, 1998
    288
    Thanks for the great ideas. I had not seen the rockets before, they very simalar to the divas, which is to say very nice. I will try to get out this weekend and give the ones available locally. I'll let you know what happens.
    Greg
  12. Vital
    Vital Extra
    Jun 3, 2003
    18
    I would go with Klipsch RB-75. They have the front ports and 8" woofers. I don't think the Rockets can touch these.
  13. GaryAR
    GaryAR Agent
    Apr 8, 2002
    45
    Good luck checking out the rockets... they'd be a great match for the sony. I'm sure you know it, but it's not an AVR. It's a class D amp... much different technology. I had the old version and I can assure you the highs aren't "laid back" by any stretch of the imagination. The micro detail was just astounding, as was bass control. I only got rid of mine because it sounded sterile and lifeless, but I think the 500ES should be much improved in that area.
    If it's not, I think a somewhat darker speaker, like the Rockets, would be better because as it would ease the slightly harsh, clinical character of the amp (I've got Onix Ref 1s, and they sounded a bit harsh with the 50ES, so I'd suggest you steer clear of similar speakers for it).
    -Gary
  14. Marty M
    Marty M Cinematographer
    Dec 6, 1998
    2,917
    11
    I also recommend you give Paradigms an audition. If the Studio models are too much, look at the Paradigm Monitor 3 or 5. If you are even considering a floorstanding speaker, I would also recommend the Monitor 7.
  15. TommyL
    TommyL Supporting Actor
    May 27, 2002
    590
    Greg, check your email[​IMG] I'll be selling some 40's etc.. really soon.
