Ive Got $1000 to spend on a sounds system for my HT
Discussion in 'Playback Devices' started by Larry*S, Nov 9, 2003.
  1. Larry*S
    Larry*S Agent
    Aug 29, 2003
    32
    a couple of things,
    I need a sound system for my theater room
    The room is 9' by 17' , strictly for theater purposes
    I know absolutely nothing about sound systems at all.
    Ive got $1000 budget (including receiver, speakers, wire..)
    From what ive read so far, staying away from HTIB's is recommended, Thats what brings me to writing this post.
    I need sopmeone to recoomend a system/ componets that are all compatible, so I dont throw away my $$$. Im very good at spending, and getting the wrong thing, so please help me out,
    actually, while your at it, you can throw a DVD player into the system (so tack on another $300 total budget of $1300, break it up as you like,
    thanks in advance,
    larry
  2. gregD
    gregD Second Unit
    Jan 16, 2003
    420
    First, do some browsing at local retailers and have them show you what $1300 buys... then investigate an authorized online dealer... here are a couple:
    Cambridge SoundWorks carries packaged systems with separates at several price points... more importantly, they make very good bang-for-the-buck speakers:
    http://www.cambridgesoundworks.com/s...=ht_systemsrec
    AC4L carries refurbished products, and has helpful customer service... one of their Marantz receivers and DVD players could be added to any one of these very decent speaker packages:
    http://www.accessories4less.com/item...PK%2DSYST&tpc=
  3. Rich Wenzel
    Rich Wenzel Supporting Actor
    Aug 9, 2002
    556
    first off, here is my recommendation, dont go full surround system right off the bat, get a good 2 fronts and build over time...you will have a much better system and that will upgrade more easily...
    the rest of my suggestions is based off of your $1300, this assumes you dont need a tv...if you need a tv, then this will be fairly different...
    dvd player Onkyo 301 $130 (dont spend more on a dvd player for a $1300 system)...
    you should be able to get a refurbed H&K 225 for under $300 on ebay direct from H&K..full warranty...
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3057403501
    thats about $500 between the onkyo and the h&k including tax and or shippng...
    this means you ahve about $700, as you have to leave room for cables (go cheap)
    you probably could put a great system together through the harman direct on ebay, by getting the infinity il series...not sure what the il50's or 40's go for, but i feel that they will be under $400 a pair, and I know you can get the il10's for rears for about $125 (i think i got a pair like that for $117)...
    actually someone has the il40's for $395 a pair brand new...i would try to win an auction on the 40's or 50's though...then you just need a center...you definitely can get the 25 or 36 for the remainder...
    if you want to buy one package all together...
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=32861
    but you will need to get stands....
    but i still say, get the other two pieces i mentioned and spend the remaining $500-700 on a pair of fronts, maybe something like the discounted axiom m60....
    Rich
