Isolating bookshelf speakers
Discussion in 'Archived Threads 2001-2004' started by Gary TP, Feb 3, 2003.
  1. Gary TP
    Gary TP Stunt Coordinator
    Sep 11, 2002
    53
    I'll be using Paradigm minimonitors for my rear speakers by setting them on top of these two tall wooden cabinet tables. What is the best (cheap) method to isolate these speakers from the cabinet...
    Could I get away with good sound through some foam, felt, etc...?
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    The cheap way would be blu-tack
    The only problem is, this may leave some residue on the shelf and speaker cabinet, and it may not be entirely simple to find locally. I wasn't able to find it locally, but I found something basically identical to it.
    You might also consider a set of small spikes, though that will be much more expensive per pair:
    http://www.partsexpress.com/images/240-715m.jpg
    Part Number 240-715 on partsexpress.com
  3. sonny_b
    sonny_b Agent
    Jul 12, 2002
    25
    check out www.auralex.com, they have a nice isolation pad for monitors called the MoPads for like $30. You can get them with free shipping at musician's friend. I was going to pick up a pair for my bookshelf but they only come in grey and the wife DK'd it.
    -sonny
