Isn't stereo enough?
Discussion in 'Archived Threads 2001-2004' started by William_K_F, Mar 8, 2002.
  1. William_K_F
    William_K_F Agent
    Feb 4, 2002
    33
    Hello,
    I have been told that since we only have two ears,
    one should be able to create a 3 dimentional sound
    with just two speakers, adjusting the frequencies
    of a sound to place it. In other words, we only hear
    things in 3 dimentions because they have different
    pitch characteristics which we interpret as placing
    them in 3-d space.
    This being the case, why bother with more than two
    speakers and a sub-woofer? Are there products out
    there that take a 6.1 (or similar signal) and process
    it so that it sounds three dimentional when coming out
    of two speakers? This way you could focus on getting
    two really good quality speakers and a sub-woofer.
    Two speakers would also go over better with my wife,
    as I am working on our bed room system. I plan to
    put the speakers into the walls if I use more than
    ones up front, but that is significant work I would
    like to avoid, if it isn't really needed.
    Perhaps the technology isn't there yet in consumer
    products to do what I want to do?
    Thanks.
    -William
  2. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Ever since it's conception "Stereo" was always meant to be
    3 full range front channels (Left Center and Right) but due
    to WAF and other Marketing logistics what we got was called
    2 Channel Stero. Companies such as Bose tout that you can
    create "Seemingly full 3D sound effects" from only "2 Speakers"
    Go listen to them and let your ears be the judge, jury and
    most likely the executioner.
    Phsycoacoustics (tricking the ears) only works in "perfect"
    rooms with superior acoustical layout and design. In the real
    world it hardly works.
  3. William_K_F
    William_K_F Agent
    Feb 4, 2002
    33
    I guess using headphones is an exapmle of "perfect"
    conditions, as this can be seen at Disney.
    So if I go 6.1 I wonder if putting the speakers into
    the walls will pose a problem since the TV is in a
    corner of the room like this and we watch from bed
    I imagine speakers at [​IMG] locations and Sub at [​IMG] behind
    TV:
    Code:
      ____________________________________
      |    [img]http://static.hometheaterforum.com/imgrepo/4/4d/htf_images_smilies_star.gif[/img]                            |
      |                                [img]http://static.hometheaterforum.com/imgrepo/4/4d/htf_images_smilies_star.gif[/img]|
      |  [img]http://static.hometheaterforum.com/imgrepo/8/8d/htf_images_smilies_smile.gif[/img] Viewer 1                     |
      |  [img]http://static.hometheaterforum.com/imgrepo/8/8d/htf_images_smilies_smile.gif[/img] Viewer 2                    /|
      |                             [img]http://static.hometheaterforum.com/imgrepo/4/4d/htf_images_smilies_star.gif[/img]/  |
      |                              /TV/|
      |[img]http://static.hometheaterforum.com/imgrepo/4/4d/htf_images_smilies_star.gif[/img]                    [img]http://static.hometheaterforum.com/imgrepo/4/4d/htf_images_smilies_star.gif[/img]    /  /[img]http://static.hometheaterforum.com/imgrepo/4/4d/htf_images_smilies_star.gif[/img]|
      |__________________________________|
  4. Jon_R
    Jon_R Stunt Coordinator
    Jan 31, 2001
    174
    That is the finest ASCII room I've ever seen!
  5. Peter Loan
    Peter Loan Second Unit
    Oct 13, 1998
    355
    Jon, for some reason...that comment had me rolling.
  6. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
  7. Mark Richter
    Mark Richter Stunt Coordinator
    Dec 15, 2001
    193
    The Ascii room is nice but the holes in the wall have to effect the acuostics so how [​IMG]
  8. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    That is very similar to the setup I have in my living room with the exception of the couch. My couch is aligned with the front stage and TV. The rears are not aligned, but they are in either corner, a few feet behind the listener. It works quite well.
    Listen to a 5.1 setup vs a stereo setup and you will understand why multi-channel is great. BUT, I still listen to most of my music in stereo... Movies sound best in a multi-channel setup, hands down. You do NOT need a perfect room to "fool" your ears, only a properly calibrated system.
  9. CarlDais
    CarlDais Stunt Coordinator
    Sep 24, 2000
    56
    Jon Sez---"That is the finest ASCII room I've ever seen!"
    Well, that gave me a good chuckle, lough
    out loud funny.
    I did something simialr many years ago
    in a 2 channel Apogee duetta set-up. But
    it was done because of the dipole nature
    the Ribbons and paticualr room acoustics.
    Meanwhile, back at the ranch.
    This is an old polemic 2 channel VS 3 Channel
    VS 5.1.....10.1 Ambisonics, ambiphonics and
    now Chesky Brothers variation on a theme of
    THX. From your diagram, a 2-channel rig is
    gonna have a very difficult time re-creating
    a sonic image of the recording venue. Stick
    with the typical 5.1 setup.
