ISF Calibration and Avia/Vide Essentials
Discussion in 'Archived Threads 2001-2004' started by Justin Woodwell, Jan 10, 2003.
  1. Justin Woodwell
    Jul 25, 2000
    22
    I plan on getting a new TV. Once I do I plan on getting it professionally calibrated as soon as possible. My question is should I still buy Avia or Video Essentials even after it has been calibrated? Will I need them?
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I would buy one, if only you use it for doing the audio calibration. The ISF calibration will cover a lor more depth than the video adjustments on a calibration DVD would though.
  3. Chris_HD
    Chris_HD Agent
    Aug 23, 2002
    34
    I would buy it 1) for the audio, 2) to better understand what your ISF tech is doing, 3) to be able to tweak the set every few months, and 4) to be able to tweak the system as you change video input components (DVD players, etc.) as the ISF tech will calibrate using your current source.
    Chris
  4. Hank
    Hank Guest
    Exactly what Chris said[​IMG]
