iScan vs. DVD player w/ digital processor
Discussion in 'Archived Threads 2001-2004' started by Ryan Rhino, Mar 3, 2003.
  1. Ryan Rhino
    Ryan Rhino Auditioning
    Feb 7, 2003
    8
    So I have the 42FD9932 Philips. Definately entry level plasma. The sell the e-box processor for about $900 if you can find one. Other option that I have found is the iScan Pro ($500 bones probably).
    My question is whether some of the newer DVD players w/ digi processors essentially do the same as the iScan and if you could use it either as a cable box for digital cable or run the outputs from cable box into DVD to utilize the signal enhancing quality.
    I'm a newbie... but have tried the FAQs and am confused to say the least.
  2. JeremySt
    JeremySt Screenwriter
    Aug 19, 2001
    1,770
    14
    Jeremy
    As far as I know, there are no DVD players that allow you to use their internal scalers on external sources. It is for the DVD player's progressive output only.
    I own the Iscan Pro V2, and I use it for Satellite, PS2, SVHS, and Laserdisc. Considering the built in scaling on my Mitsubish RPTV is crap, the Iscan is a huge improvement. My DVD player utilizes its own scaler.
    My guess is that the Iscan Scaler is better than the "ebox"
