IScan Pro Question
Discussion in 'Archived Threads 2001-2004' started by Manuel, Nov 9, 2001.
  1. Manuel
    Manuel Stunt Coordinator
    Jun 29, 1999
    199
    Will this unit pass the S-video and composit signal out through the component out? In other words, can this also function as a S-video/composite in to component out box?
    You've never worked in the private sector. They expect results.
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Yes, but only as progressive scan output.
    The iScan outputs 60 Hz 640 x 480 VGA (RGB) non-interlaced, or 480p component video, which incidentally represent the same frame rate and scan rate.
    More on line doublers http://members.aol.com/ajaynejr/viddoubl.htm
