Is using black electrical tape a no-no when building interconnects or speaker cabless
Discussion in 'Accessories, Cables, and Remotes' started by Lam Nguyen, Jun 26, 2003.
  1. Lam Nguyen
    Lam Nguyen Stunt Coordinator
    Nov 29, 2002
    108
    I've been reading on the Jon Risch interconnect and others, and they all recommend using the white plumbers tape on interconnects and speaker cables. Does the black electrical tape degrade the quality in some way?
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    it would be rather remarkable if it did however there may be sound mechanical and aesthetic reasons for choosing one over the other.
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    Your post is a little confusing, Lam. What is the tape being used for? Splicing? Aesthetic decoration? To bundle wires together?
    Wayne A. Pflughaupt
  4. Matt_Doug
    Matt_Doug Stunt Coordinator
    Feb 12, 2003
    106
    White plumbers tape like the very thin kind that's used between the threaded joints of water pipes to prevent leaking is made of Teflon which is an excellent insulator. That may be the reason its recommended. But as Wayne also asked, what is the tape being used for?
  5. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    ...or labels?
    Hi Wayne!
  6. Kevin Deacon
    Kevin Deacon Second Unit
    Dec 18, 2001
    319
    It definately has to to with Teflon. The Teflon tape is used to wrap the silver wire around some kind of core material like tubing or cotton rope. Many of John Risch's recipes call for a certain kind of Belden coax cable which has a foamed teflon wrapped copper center wire.
    Teflon rules for DIY audio IC's and speaker wire.
  7. Lam Nguyen
    Nov 29, 2002
    108
    the black tape is just use to wrap around the Techflex and interconnect to keep the techflex it in place, I was affraid the heatshrink was not enough. Thanks for the reply so far.
