Is this wirelwss system any good for rears?
Discussion in 'Archived Threads 2001-2004' started by Meaux, Sep 19, 2001.
  1. Meaux
    Meaux Stunt Coordinator
    May 27, 2001
    168
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    forget it...it only has a 10w amp! there's no way it's going to have enough power for your rears.
    the fact that the sound is transmitted wirelessly also worries me. i'd be worried about fading, loss of quality, etc.
    plus, it still looks like you need to be near a power outlet. so there's wires anyway.
    if, at all possible, run the wires. if not, then i guess it's worth a try...
    You step in the stream,
    But the water has moved on.
    This page is not here.
    [Edited last by Ted Lee on September 19, 2001 at 05:17 PM]
  3. Meaux
    May 27, 2001
    168
    Wonder if it's possible to "transmit" the low level side and have the 200wpc amp to power the rears? Low level converter? Wonder what it will do to the timing of the rears.
    Meaux
    Daydreamin I guess.
