Charlie G
Grip
- Jan 17, 2001
I'm looking to build a sub (or subs) to fill in the bottom end on my speakers, which are 103-104db/watt/meter efficient 100hz exponential horns. It's not quite so much a sub as a 'woofer', since there is some response in the >100hz range.
I'm rather limited on space, so I was fiddling with some 18" drive units and found that with two 18's in a 6 cu foot sealed box, (or one each in 3 cu foot) I get some interesting numbers. Down low, output is obviously limited by excursion (only 7mm each way on these high-eff woofers). But, I still have plenty of output at say, 30hz (>110db anechoic) The problem is, Qts is above 1, so response continues to rise quite a bit.
So, the subs would have the output I need down low, but the reponse continues to rise as frequency does, up to >125db anechoic, at max power. So I just kinda need to cut off the high freqs, level everything off at about the 30hz level, and let it roll off below that.
I have two concerns:
Is this what a linkwitz transform is for? Even if it lets me simulate a larger box, even if the Qts were actually down around 0.6, the response still rises too much, I still need to shelve it off at about the level it is at at 30hz.
I figure with a Behringer, and some simple opamp filter if needed, I can probably get the response to what I want, but this also concerns me:
Apart from the frequency response (which will be corrected), what are the cons of such a high Qts? I think this refers to the 'damping' of the box, does it not? If the box is 'underdamped' will there be excessive distortion or anything like that?
EDIT: Just ran some more numbers.. if I give each woofer its own 4-5 cu foot cabinet (around a 21" cube, heavily stuffed), I get response around 112db anechoic @ 30hz w/ 125 watts into each woofer. This also lowers the Qtc to about 0.72, which I like a whole lot more.
It's unlikely I'd EVER play music this loud, and these numbers are *right* on the excursion limits for the woofers, but it's nice to have some headroom. Means the woofers are just putting along at normal listening levels, which is good
Charlie
Charlie
