Manuel Parrado
- Jan 7, 2001
On "Convergence 1" on my Panasonic 53wx52, the first adjustment you make is labeled as "green" and is simply a thin green cross in the middle of the screen going from the center to the edges of the screen. There are four tiny marks on the inside of the bezel to line up with each leg of the cross.
When I center the cross as much as I can, I notice the upper leg of the cross is offset to the right of the marker and the lower leg is offset to the right. In other words, the screen is slightly rotated clocwise from center.
Is this a geometry problem correctable through the service menu or otherwise?
