Luis M
- Jul 2, 2000
I own the Panasonic RP-91 and like most people I am very pleased with its performance. But I am having a little problem with the player when the progressive mode is engaged.
I noticed huge brightness fluctuations on many scenes where there was movement and where dark and bright objects shared the screen. Let me first say that I could not detect this anomally with the panasonic player playing interlaced signals. Also my HD projection tv (65" RCA SCENIUM) "COULD NOT" display the BELOW BLACK BAR found on the VIDEO ESSENTIALS dvd in the pluge pattern test, neither in progressive or interlaced modes. (NOTE THAT THE INABILITY TO PASS THE BELOW BLACK BAR WAS ONLY SEEN WITH THE COMPONENT CONNECTIONS, ONCE A S-VHS CABLE IS USED, THE TV EASILY HANDLES THE BELOW BLACK TEST PETTERN)
No matter what icons I changed on the panasonic reguarding the darker or lighter possitions the dvd showed the same problem. I usually keep the Panasonic on auto and I chose the "PROJECTION TV" mode to display the picture.
On the Jurassic Park dvd - Chapter 4 and 17:45 minutes into the movie as the airplane glides in the montain range you can clearly see huge variations in the brightness intesity and as the plane takes center stage the montains become very dark in a flash (a problem not present when playing other dvd players or the Panasonic with an interlaced signal).
Maybe some of you can check this out with your players or help me out on what could be causing this problem.
1-None of the dvd plyers show the problem while playing interlaced signal, including the panasonic (the panasonic dvd player is my only progressive unit)
2-All the units show the below black pattern on the Video Essential dvd when connected with a S-Vhs cable "NOT SO" when component cables are used
