Is this Kenwood HT System any good?
Discussion in 'Archived Threads 2001-2004' started by Brenton, Aug 28, 2002.
  1. Brenton
    Brenton Screenwriter
    Jun 25, 2002
    1,169
    I am looking for an adequate home theater audio system (reciever and speakers), but I am on a serious budget. I found this on BestBuy.com, it's a Kenwood 600-Watt Dolby Digital/DTS Home Theater Audio System with Pro Logic II Decoding.
    I know that at less than $300, it's not gonna be too spectacular, but my question is would it be adequate for someone who's just getting into the HT game and has never had anything better than TV speakers in his life? Or is it just offensively awful? (If it makes a difference, I'm a sixteen-year-old who's making money mowing lawns, thankfully my grandmother way overpays)
    If it is "offensively awful", can you recommend anything better that's still in the "$300 or less" price range? Any help will be appreciated.
  2. TimG
    TimG Second Unit
    Oct 5, 1999
    361
    I know earlier Kenwood "Home Theater In a Box" systems got pretty good reviews for what they are. I don't know how much they have changed though. I think this would be a great starter system for someone, then later it could be moved into the bedroom. You might want to say what your budget is, then let people offer opinions.
    TimG
  3. Brenton
    Jun 25, 2002
    1,169
    I did say what my budget is. About $300 or less.
    As for being a great starter system, that's exactly what I had in mind. I envision replacing it piece-by-piece as I get money.
  4. DannyL
    DannyL Stunt Coordinator
    Dec 18, 2001
    77
    this may be of some help. i was in the market for a home theater in a box for my video game systems. i listened to quite a few of them and i wound up purchasing the kenwood htb-505. for me, the deciding factor was that the speakers did not offend my ears. most of the other systems i listened to, the speakers sounded like a clock radio. now, do these compare to my martin logans, not even close, but they serve my purpose. i would suggest listening to them in the store. the htb-205 that you are looking at uses smaller front speakers than the htb-505.
  5. Brenton
    Jun 25, 2002
    1,169
    Did you listen to the HTB-205 specifically? If so, would you consider it "bad"?
    I would really like to consider the 505, but my budget is very, very tight. And so unless the 205 sounds "like a clock radio", I probably won't be looking at the 505. (That is, unless I can borrow about $174 from my dad.)
  6. Bill Will
    Bill Will Screenwriter
    Dec 26, 2001
    1,282
    If I was you I would get the Kenwood & try it out for yourself at home. Nothing you listen to in the store is ever going to sound like it does once it's installed in the home & if you don't like it return it to Best Buy before their 30 day return policy runs out. Myself I think the Kenwoods for the money are the best HTB systems out there. The Kenwood receiver in the HTB is a half way decent receiver & you can always upgrade the speakers when you get the money. My only other suggestion would be to buy the Panasonic Receiver SA-HE100 (comes in black or silver) that will decode "ALL" the new formats & has Dolby Pro-Logic II that is fully adjustable. The SA-HE100 has 6 built in amps with the 6th for the rear center speaker in Dolby Digital EX & DTS-ES. This receiver has been getting great reviews & can be had delivered on the internet for $250, but then you would have to save up for speakers or just get the 2 main front speakers & then add the surrounds later. If you can't wait or save up to get the speakers, I would say give the Kenwood a shot, but remember the receiver you buy today you will probably have for some time to come so I would consider the Panasonic.
  7. Albert M
    Albert M Stunt Coordinator
    Jun 19, 2001
    222
    I would save up the money and buy the HTB-505,this store has the HTB505 for $379.97 plus shipping.
  8. DannyL
    Dec 18, 2001
    77
    i did not listen to the htb-205- it was not set up in the store. the front speakers (visually) do not look like they are the same quality as in the htb-505.
  9. Brenton
    Jun 25, 2002
    1,169
    I've decided to get the 505 if I can manage to get ahold of the extra money. If not, I'll get the 205. I can always upgrade the speakers later.
    Thanks for all the help, I really appreciate it.
