Is there any point in calibrating my setup?
Discussion in 'Beginners, General Questions' started by JaymeF, Sep 8, 2003.
  1. JaymeF
    JaymeF Agent
    Apr 29, 2003
    25
    I'm not a home theater nut like most of you here [​IMG] but I do want the best out of my system. It isn't anything special, but it does me good. I currently have a Sony Wega 32" Flat screen (non-HDTV) and a Kenwood HTB-454 Home theater in a box. I am just wondering if it would benefit me any in using one of those calibration discs such as Avia or Video essentials? or are these more for higher priced systems, and HDTVs?
  2. Jay Blanchard
    Aug 19, 2003
    23
    The Avia video calibration alone is worth the cost of the disc, in my opinion. My HDTV has never looked so good.
    I don't know what type of calibration your receiver is capable of, but I would recommend calibration of it if there is any at all.
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    All consumer displays benefit from some sort of calibration. AVIA is the lease you could do.
  4. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
  5. Jay Blanchard
    Aug 19, 2003
    23
    Yeah, the problem I've always had with getting a good picture on my TV's is that the source you use doesn't usually have proper coloring due to lighting in the actual source. If you use the face of a person sitting in front of a fire in a movie to balance your flesh tones, you're going to get bad results elsewhere. Using a calibration disc doesn't have that problem.
    I learned a lot in the process of using the disc too. Such as sharpness and picture being wrong when set too high. Also, I was able to use some of the geometry test patterns to figure out convergence and centering problems I had overlooked in my HD's setup.
  6. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    For STARTERS, I recommend the very nice junior disk from the Avia people -- the Sound&Vision Home Theater Tune-Up.
    It sells for around $16 at amazon.com (and elsewhere).
    Not only does it have the same tv user settings for Contrast/Brightness/Color/Tint/Sharpness, it has Dolby Digital and Dts sound tracks to balance your speakers using a $35 Radio Shack analog sound pressure level meter.
    Works for both 6.1 and 5.1 spkr systems.
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    yep, i was also thinking the s&v tuneup dvd would work for you. it's not as expensive as the others, yet it has a comprehensive set of audio and video calibrations.
    think of it this way, it's about the same cost as a music cd, four trips to mcdonalds, or a nice dinner. yet, for that same cost, you'll be ensuring that you're getting the most out of your system.
    well worth the price of admission.
  8. JaymeF
    JaymeF Agent
    Apr 29, 2003
    25
    Great, thanks! I will most likely be picking up one of these discs soon and see what it can do for me [​IMG]
