Is there an easy way to bring a 55Mits up to the second floor in a straight stairway?
Discussion in 'Archived Threads 2001-2004' started by Dodie, Jan 22, 2003.
  1. Dodie
    Dodie Agent
    Nov 1, 2002
    31
    Is there an easy way to move my 55inch mits to the second floor of my house? The stairway is straight up with no landing. Can I tilt the RPTV? Is there any equipment that can be rented that you can recommend to be used is moving this tv upstaits?
  2. Jim Williams
    Jim Williams Second Unit
    Oct 29, 2002
    367
    You could rent a stair climbing hand truck. I have seen them used and theorhetically a single person could move a 700 lb item up the stairs.
  3. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    Dodie,
    Please tell me you aren't trying to do this yourself! The best "equipment" you can rent is a couple of strong backs.
    Yes, you can tilt the set (I assume you mean that one end will be higher than the other), but don't up-end it!
    Easy? No. But it can be done if there's enough width on the stairway.
    Jan
