The new, possibly unreleased ATI All-in-Wonder Radeon 9700 has a component output breakout cable, if you're looking for an easy all-in-one solution. Unfortunately, I have no idea if 1920x1080 output is possible, Macrovision legal restrictions may not allow it.
Expect fuzzy text. At least, at 1440x540, text is readable, but it won't be anywhere near sharp as a decent VGA monitor. Should be good for video though.
I have a TW40X81, it's only a 40" display. Too bad my computer is too damn loud. I really should try liquid cooling to stay under 25 db of noise.
Check http://www.altex.com/ and search for "bnc" (called "15-pin High Density D-Sub") The two at the bottom of the search page that are under VGA are what you want.
Two of the five BNC connectors are not used, just let them hang.
This will let you do HD from a pc. Use powerstrip to figure out the highest resolution that your tv will handle correctly.
Matt, you sure those will convert SVGA to component video? I can't see how those would work at all! If you have those cables and got them working, what video card did you use?
Matt/Max: That won't work unless the video card can be switched to output a component (YpYbYr) instead of a VGA (RGB-HV(sync)) signal. That's why, in most cases, a transcoder is needed.
This does work on a device like the Iscan, for instance, because it has a switch on the back to switch between VGA and component.
Thanks Bill. I have a transcoder myself, and couldn't figure out how those cables would work on any of the current video cards except for the new Radeon All-in-Wonders.
I have the Audio Authority VGA-to-component transcoder. Works pretty well, after I had it replaced when the first one blew up (but a good friend fixed the original one, because he kicks ass).
