Chuck C
- Jan 6, 2001
Is There A Layer Change with DVD-Audio? Is DVD-A recorded onto DVD-9 discs?
Having said that there are differences among players but none of them are really seamless.
Actually, my ProScan PS8680Z was completely seamless 9 times out of 10. A really amazing machine at layer changes. Also, computer based players like many Apex players are seamless as well.
Also, I thought the Columbia "Superbit" branded releases were engineered to be seamless on most players.
they are desgined to be seamless, but they are also slightly out of spec in doing so, which causes problems in some older players
This is true only to a certain extent, as there will always be a very slight pause at the forced layer break when defined as "non-seamless" per DVD spec.
So far, the best we've tested is ~ 1/4 of a second.
Well, you could call "time required to do a non-seamless transition" a third variable along with memory buffering and loader response time. There is no fundamental reason that a seamless transition has to be visible, and as an earlier poster mentioned, PC software players could do it within a field time. A non-seamless transition doesn't mean the player MUST flush all of its buffers, it just means it has to reset enough internal state (e.g. MPEG decoder state) when it needs to actually switch from one stream to the other. Whether this could be done imperceptibly fast depends on chip design.
However, the buffer design required for this is a pain, so there isn't much point to it unless the loader and memory are sufficient for rapid "non-seamless" transitions. The layer change is the only case where people get really annoyed by non-seamless transitions (this kind of transition also happens when you use certain fast forward/backward modes, but those tend to always have pauses because LOTS of loader and decoder muscle is required to make, say, 16X scan look smooth).
