Is there a dual-benchmark disc that can be used for both the DVD-A and SACD formats?
Discussion in 'Playback Devices' started by John Pine, Dec 5, 2003.
  1. John Pine
    John Pine Supporting Actor
    Feb 27, 2002
    989
    6
    110
    John Pine
    I'm new to the DVD-A/SACD formats. I have an AVIA disc that I've used with my trusty RS meter in the past. In a few weeks, I hopefully will be buying a Denon 2900 that it will be used for.
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Chesky has his Ultimate 5.1 Setup Disc (I think that's the title).
    AIX has setup material on their latest 5.1 sampler as well.
    I'm not sure what's out there for SA-CD.
    Cheers,
  3. John Pine
    Feb 27, 2002
    989
    6
    110
    John Pine
    John, those are for DVD-A only? Will I have to buy one for each format?
  4. Steve_AS
    Steve_AS Second Unit
    Feb 4, 2002
    412
  5. Steve_AS
    Feb 4, 2002
    412
  6. John Pine
    Feb 27, 2002
    989
    6
    110
    John Pine
    Thanks guys!
  7. Brian L
    Brian L Cinematographer
    Jul 8, 1998
    2,918
    15
    610
    Of course, if you have both formats, which do you use to calibrate the system?
    I use the Chesky disc DVD-A tracks for my Pio 45a, and find that both SACD and DVD-A stuff played through the player sound fine.
    Of course, when I do get a SACD test disc, I will probably find that my SACD channel balance has been all wrong!
    BGL
  8. Steve_AS
    Feb 4, 2002
    412
  9. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    I found that DD through the analog outputs is *close* to the Chesky DVD-A disc.
    I even have that DMP SACD disc, but haven't gotten to it yet! [​IMG]
    I think that I have become more of a believer in tweaking the sub by ear. I did it for years with Avia, and ran it 2-3 dB "hot", but I always felt it was too loud for movies. Now I have it down by about 5 dB, and much prefer it. I think most people miss that because the Radio Shack meter is less sensitive to lower freqs, that means you should lower the sub's level, and not increase it. But you have to think about that for a few seconds before it makes sense. [​IMG]
  10. John Kotches
    Mar 14, 2000
    2,635
    Kevin,
    Very true. For subwoofer calibrations with my RS meter, I read between 72-73dBs. This ties into something I've been saying for a while.
    In normal operation if you notice the subwoofers presence, it's too loud [​IMG] The only time you should be aware of its presence is if there's content that you know your main speakers cannot handle.
    While I understand the adrenaline rush from exaggerated LF response, I find that it seriously detracts from the overall experience.
    Cheers,
  11. John Pine
    Feb 27, 2002
    989
    6
    110
    John Pine
    I been looking around for a retailer for this disc. But, the Chesky Setup Disc can only be ordered directly from Chesky Records, right?
  12. John Kotches
    Mar 14, 2000
    2,635
    John,
    THat's the only place I've ever found it was through the web site.
  13. Kevin C Brown
    Aug 3, 2000
    5,712
    I just saw it in Music Direct's print catalog.
