I try to download stuff now and it always stops before the last 100k and says you have run out of space on your drive. Do I have a virus? Does anybody get this. I definitely have space left.
Do you have more than one drive or partition (e.g. a C drive and a D drive)? If your Temp or Temporary Internet Files folder is on C, and you run out of space, even if you're downloading to the D drive, you can get an error.
Also, if you have corruption on the drive, it could cause a problem. Run Chkdsk on NT/2000/XP or Scandisk on 95/98/ME to check this.
So, in short, check the free space on all your drives. Also, if you run low on swap space you can get problems like that too. I recommend that the drive Windows is installed on not drop below say about 100MB of free space (depending on the total size of the drive).
