David Gibbons
- Feb 24, 2002
Dear HT Folks,
I have done calibrations at my high-tech company for years, and there is a lot of freight that comes with the word.
In our adjusting our home theater equipment, it seems like we are not quite doing formal calibrations as much as developing baseline settings which will give us a known starting point.
Particular films or shows may have too much of one thing, or too little of another. We thus may want to reduce the subwoofer, or increase the treble, or "back off" the center channel to watch that particular show.
However, having a known neutral point to return to after making compensations is useful.
I would suggest that adjusting our systems using any of the known-good test disks is better called by another term than calibration, because calibration implies that one can ONLY use the settings developed if one wants to be correct.
Adjust; Setup; Tune; Initialize; Create Default; Set
All of these above words can be used - but which (if any) works better for you than the commonly-used "calibrate"?
I have done this process on 4 different systems now, and whatever you call it, the systems' owners were pleased and surprised at the improvement it made.
I do suspect this baseline adjustment does provide 90 or more percent of the possible performance of typical home theaters in the typical home.
If you haven't gone and bought your Avia or Video Essentials disk and cheap Radio Shack sound meter yet, do so!
Sincerely,
David Gibbons
Sincerely,
David Gibbons
